Press the Buttons
- 08 Aug 2024
- 220
This guide will show you how to set up the buttons on your MOTION 2350 Pro through coding.
The figure below shows the GPIO for each of the on-board push buttons.
3. Flash the codes to your MOTION 2350 Pro. And your CIRCUITPY drive should look like this (no lib file is used):
