Lighting Up the RGB LED
This guide will show you how to light up the RGB LED on your MOTION 2350 Pro.
The figure below shows the GPIO for each of the on-board status RGB LEDs.
3. Flash the codes to your MOTION 2350 Pro. And your CIRCUITPY drive should look like this:
    Library file(s) required:
    neopixel.mpy
