DC Motor
DC Motor
This guide will show you how to power up the dc motor through your MOTION 2350 Pro.
The figure below shows the GPIO for each of the motor terminals on MOTION 2350 Pro.
Select the Suitable Power Source
The volatge supply at the 2 motor channels is the same as the voltage rating of the power source connected to the board.
Hence, MOTION 2350 Pro can support a range of DC motors with different voltage rating, ranging from 3.6V to 16V.
The following figure shows the example connection of 2 DC motors with different voltage rating with their respective power source stated
  • TT motor (3-6V)
  • 12V DC motor
Connection and Coding
2. Connect 2 DC motors to both DC Motor Terminals (Black Colour).
Note: You can always test the connections of the DC motor wires whether the wires are properly connected to the terminal block by pressing the motor test buttons labeled M1A, M1B, M2A or M2B while your MOTION 2350 Pro is powered up and switched on.
In order to let the motor run in forward direction, press the “MXA” button only. If you wish to change the direction of the rotation of the wheel, you can loosen the wires and swap the wires connected to the terminals.
4. Flash the codes to your MOTION 2350 Pro. And your CIRCUITPY drive should look like this :
Library file(s) required:
