Displaying Text on SSD1315 OLED module via I2C
- 08 Aug 2024
- 216
This guide will show you how to display text on OLED module using your MOTION 2350 Pro through I2C on Maker Port or GPIO Breakout.
The figure below shows the available I2C pins on each maker ports.
1. While your MOTION 2350 Pro is connected to your computer, open your editor software (for example Thonny). Select the code.py file in your drive.
2. Connect your OLED module to Maker Port with GP 26 & GP27 using JST-SH to 4 female pins / grove cable.
OR connect your OLED module to the GPIO breakout using male-to-female jumper wires.
4. Flash the codes to your MOTION 2350 Pro. And your CIRCUITPY drive should look like this:
Library file(s) required:
File(s) required:
font5x8.bin
