NodeMCU Kit using Telegram : Light Control
- Aishah Kamal
- 26 Aug 2024
- 25
Project 4 : Light Control Using Telegram Bot
- Control the LEDs remotely using Telegram Bot
- Required Components : ESP8266, Breadboard, three resistor (optional), four Male-to-Female jumper.
Step 1 : Connect the jumper as the shown picture, pin D1 to red D2 to yellow D3 to yellow :
Download the code here !
Output:
Write the prompt to on and off the LED's
