5V & External VIN Servo Motor
- 05 Jun 2024
- 145
This guide is about controlling the micro servo motors by using the 8 servo motor ports on the MOTION:BIT Pro.
Servo Ports on MOTION:BIT Pro
There are 8 servo motor ports on MOTION:BIT Pro with 3 different coloured connectors.
MakeCode MOTION:BIT Servo Motor Block
Hardware Setup: 5V or VIN?
MOTION:BIT Pro allows you to control a micro servo motor (5V) with on-board power source or high torque servo motor (7-12V) by connecting external power source.
Note: Check your servo voltage rating before you connect it to MOTION:BIT Pro
Case 1: 5V
Example connections: MG946R Metal Gear Servo
Case 2: VIN for 7-12V
