![Getting Started with MOTION:BIT Pro Getting Started with MOTION:BIT Pro](https://static.cytron.io/image/tutorial/getting-started-with-motion-bit-pro/motionbit-pro-gsg-main.png)
- 05 Jun 2024
- 398
MOTION:BIT Pro is an expansion board that is designed to simplify motion control using 12V DC Motor or Servo Motor with micro:bit.
This getting started and projects guide will help you to kick start your MOTION:BIT Pro projects with some simple guides, hardware setup or example codes including:
- MakeCode Extensions and Flashing the Code
- DC Motor
- Micro Servo Motor
- Li-Ion Battery and External Switch
- Maker Ports (qwiic) and GPIO Breakout
- RGB LED and Daisy Chained RGB LED
- Remote Control via Bluetooth using Smartphone
