Micro Servo Motor
- 30 Mar 2023
- 505
This guide is about controlling the micro servo motors by using the 8 servo motor ports on the MOTION:BIT.
Servo Ports on MOTION:BIT
There are 8 servo motor ports on MOTION:BIT with 3 different coloured connectors.
The voltage is equal to power source voltage (3.6V-6V)
MakeCode MOTION:BIT Servo Motor Block and Hardware Setup
Example connections: SG90 Micro Servo
