Li-Ion Battery and External Switch
- 30 Mar 2023
- 501
This guide is about inserting the 18650 Li-Ion Battery and External Switch on the MOTION:BIT.
MOTION:BIT comes with an onboard 18650 Li-Ion Battery Holder, so you can use the rechargeable 18650 Li-Ion Battery to power up your MOTION:BIT project.
Note: The design of the 18650 Li-Ion Battery should have flat surfaces on both ends to fit into the battery holder on the MOTION:BIT.
External Switch
There is a pair of pin connectors for you to connect an external switch to your MOTION:BIT board on your robot enclosure.
Note 1 : The pin connectors are polarity insensitives
Note 2 : Always switch OFF the onboard switch if you wish to control the power of the MOTION:BIT solely on the external switch.
Note 3 : The external switch are not meant for push switch buttons.
Switch used on figure: Rocker Switch with Wire-20CM
