![Get Started with Blynk 2.0 on micro:bit | IoT for Beginners Get Started with Blynk 2.0 on micro:bit | IoT for Beginners](https://static.cytron.io/image/Alhamed/Blynk%20-%20Thumbnail.png)
- 02 Dec 2022
- 1111
Blynk is an IoT platform that is used to control hardware remotely, it can display sensor data, it can store data, visualize it, and do many other cool things. In this tutorial, we will learn how to get started with the new platform of Blynk on micro:bit using the Grove WiFi 8266 module.
Blynk Setup
- go to Blynk website, create a new account and log in
- create a new template
- from datastream add a virtual pin
- then add a new device
- from web dashboard add a switch
- now copy the token and let’s start making the code for micro:bit
- Paste the Token that you have copied from Blynk, and type in "V0" in Pin section
Project Complete
Now you can control the micro:bit via Blynk, go ahead and improve this code and make great IoT projects.
