![Displaying on MAX7219 Dot Matrix Using Arduino Displaying on MAX7219 Dot Matrix Using Arduino](https://static.cytron.io/image/tutorial/displaying-max7219-dot-matrix-using-arduino/Maker-UNO-Dot-Matrix-HD.jpg)
- 05 Dec 2018
- 804
UPDATE
Certain 4 In 1 MAX7219 Dot Matrix Display Module uses different hardware definition in coding. If you have trouble following steps provided in the tutorial (which is using FC16_HW), you can try another hardware types as shown below:
- PAROLA_HW
- GENERIC_HW
- ICSTATION_HW
Previously, I share 2 tutorials explaining how to use MAX7219 dot matrix display with Raspberry Pi:
- Displaying on MX7219 Dot Matrix Using Raspberry Pi
- Displaying Telegram Message on Dot Matrix Using Raspberry Pi
Now, I want to share how to display on 4 In 1 MAX7219 Dot Matrix Display Module using Maker UNO (Arduino).
This video shows how to interface MAX7219 Dot Matrix with Maker UNO (Arduino).
Wiring between MAX7219 Dot Matrix with Maker UNO
4 In 1 MAX7219 Dot Matrix Display Module | Maker UNO |
VCC | 5V |
GND | GND |
DIN | Pin 11 |
CS | Pin 10 |
CLK | Pin 13 |
Thank you
References
- MD_MAX72XX from majidDesign
- MD_Parola from majicDesign
