This tutorial is short summarizes on common issues with ESP8266 or ESP32 Arduino base boards. It usually happens while tinkering with Arduino IDE and ESP chips...
Wireless control of the mobile robot is made possible through the use of a wireless joystick via TinyUSB. In essence, this marks an improvement to the device information project by integrating the re..
The Hardware Interface Device (HID) is identifiable when the device is connected to the externally installed Type A USB host connector, which is derived from TinyUSB...
 MDDS10 is the SmartDriveDuo-10 whereby it has the specification of MDD10A which is capable to drive two brushed motors bidirectionally at 10Amps each and with the addition of smart f...
To build this robot, there are quite a number components and 3d printed parts are required. Hence this will be separated into two two different parts. First we will look at the components, and next we..
PREREQUISITES: This tutorial assumes that you are familiar with Arduino Boards, Arduino IDE Software, Serial Monitor, micro:bit and how to download program into micro:bit.....
Push-ups are a very useful technique to build muscles and strengthen your upper body. However, it must be done in the right way or else it may cause injuries or pain in the back or shoulders. On the o..
In this simple tutorial it is demonstrated how to interface the PCT2075 temperature sensor with Maker Pi Pico and display the value on the Sparkfun RGB LCD. The PCT2075 temperature sensor by NXP is a ..
In this tutorial we shall see how to detect the RGB color using Raspberry Pi Pico and APDS 9960 sensor. The result is then displayed on the Sparkfun RGB lcd. Basically the sensor is capable of detecti..
