![Send and Receive SMS Using TTGO ESP32 SIM800L Send and Receive SMS Using TTGO ESP32 SIM800L](https://static.cytron.io/image/tutorial/send-and-receive-sms-using-ttgo-esp32-sim800l/TTGO-T-Call-ESP32-SIM800L.jpg)
- 17 May 2022
- 5279
In Malaysia, project with GSM is still popular among students. I always search for simple and low cost solution for this application. Introduce TTGO ESP32 SIM800L board, that consists of WiFi, Bluetooth, GSM and GPRS in a single board. Plus, you can program it using Arduino IDE. So, today I would like to share how to get start with TTGO ESP32 SIM800L board and control relay through SMS.
This video will show you how to get start with TTGO ESP32 SIM800L board and control relay through SMS.
Update 18 May 2022: I created a base for this tutorial so that the boards can be arranged more neatly.
- TTGO T-Call ESP32 with SIM800L GPRS Module
- 1CH Active H/L 5V OptoCoupler Relay Module
- USB C to Type A Cable (1 Meter)
- 40-Way 10cm Jumper Wire (Male-Female)
- 3D printing products
This is Arduino sample program to control relay with SMS "RELAY ON" and "RELAY OFF". Please install 1 additional library at Arduino IDE Library Manager:
- Adafruit Fona Library by Adafruit Version 1.3.10
- Adafruit Fona Library - GitHub
- ESP32 SIM800L: Send Text Messages (SMS Alert) with Sensor Readings
USB Type C Cable (1 Meter)
RM8.00
Artillery Hornet 3D Printer - Partially Assembled
Discontinued
40-Way 10cm Dupont Jumper Wire
RM2.30 RM3.40
