Object Sense With Servo Using Maker Pi RP2040
- 08 Jun 2021
- 1367
This tutorial shares how to move the sensor using a servo motor to detect objects. When the object distance is less than 200mm, a buzzer will sound.
- Maker Pi RP2040
- M5Stack ToF VL53L0X Sensor Unit
- RC Servo Motor (Metal Gear)
- USB Micro B Cable
- (Optional) LiPo Rechargeable Battery 3.7V 1300mAH
This is CircuitPython example code to control the servo motor and read the distance sensor. Please include these 4 libraries from CircuitPython Libraries bundle.
- adafruit_bus_device
- adafruit_motor
- adafruit_vl53l0x
- simpleio
