Monitoring Soil Moisture Using Blynk and micro:bit
- 09 Dec 2022
- 1162
With this IoT system, you can monitor the soil moisture of your plants using micro:bit and soil moisture sensor. The sensor readings are collected and transmitted to Blynk cloud server, therefore, you will be able to keep an eye on your soil moisture level from anywhere using your phone.
- Connect Maker Soil Moisture sensor to P2
Blynk Setup
- go to Blynk website, create a new account and log in
- create a new template
- from datastream add a virtual pin
- then add a new device
- now copy the token and paste it into the micro:bit code
- on your phone, open Blynk app and click on micro:bit device
- from the widget box, add a Gauge and select virtual pin 0
- Paste the Token that you have copied from Blynk, and type in "V0" in Pin section
Project Complete
Now you can monitor the soil moisture using Blynk app on your phone. The higher the value, the dryer the soil.
