IRIV PiControl - Updating address/baud rate of moist Sensor
- Abdulkareem Bageri
- 13 Sep 2024
- 41
By the end of this guide you will update the address and baud rate of the 3 in 1 moist Sensor on IRIV
- IRIV PiControl
- 24DCV power supply
- 3 in 1 moist Sensor
Connection Diagram
Note : the DC voltage used is 24V.
Programming with Node-RED
Inser an inject node from the coomon platter. we will use this one to send command
Insert a function to the flow.
In this function add the following code.
let current_id = 0x01
let new_address = 0x03
var buf = Buffer.from([current_id, 0x06, 0x02, 0x00, 0x00, new_address, 0xC8, 0x73]);
msg.payload = buf;
return msg;
Note that the current_id is set to 1 as defulte and you need to change it in case you changed the id before.
While new_address is the address that you want to set/
The last 2 items in the buffer 0xC8 and 0x73 is the crc, which are values depending on the first 6 items and you will need to calculate that .
Insert a serial request node.
Set the proerties as the following.
Note: in case you did not recive a respone from the port, change the baud rate to 4800.
insert a debug function
Connect the nodes, click on the square in the timestamp to send the changing command.
Check the debug side bar. if you recived a respone that means that the address is changed successfully
Now add another inject and function nodes to send the change baud rate command.
the code for the change baud rate is as following :
let new_speed = 0x02 // from data sheet 0x02 = 4800 baud rate
var buf = Buffer.from([current_id, 0x06, 0x02, 0x01, 0x00, new_speed, 0x58, 0x73]);
msg.payload = buf;
return msg;
Connect the function node to the server. send the command and check for a respone
Note that you will need to update the proberites of the server in case you changed the baud rate for the sensor to respone the command.
If you want to know more on how to get readings out of this sensor follw this link.
