Chapter 5: EDU PICO Attendance System
- Solehin Rizal
- 06 Jun 2024
- Advanced
- 59
This project uses EDU PICO and HuskyLens' powerful face recognition to mark attendance. Simply walk by the system, and it'll identify you. A press of a button confirms your arrival or departure, with everything neatly recorded in a downloadable CSV file for easy tracking.
This chapter explores building a smart attendance system that uses face recognition for user identification.You'll learn :
Face Recognition with HuskyLens: Learn how to configure HuskyLens to recognize faces and identify individuals.
User Management and Confirmation: Discover methods to store and manage user data. Implement a confirmation button to ensure attendance accuracy.
Data Recording with EDU PICO: Explore how to record attendance data in a downloadable CSV file for easy tracking and analysis.
Tutorial Video
Tutorial
Step 1 : Library Installation
Install the additional library required for this chapter here.
Step 2 : Configuration Setup
Create a new notepad file and copy the provided code:
CIRCUITPY_WIFI_SSID = "Your-Wifi"
CIRCUITPY_WIFI_PASSWORD = "Wifi-Password"
Modify the SSID and Password with your Wi-Fi credentials and save the file as "settings" in CIRCUITPY.
Copy boot.py from source file here to your CIRCUITPY.
Step 3 : Face Learning
Use HuskyLens, go to “Face Recognition” to learn faces .
Step 4 : Code
Go to Line 53 and modify the code by replacing the person's face name.
Step 5 : Data Log Function
Enable the data log function to record attendance data.
Step 6 : Testing the Program
Test the functionality by using Button A for check-in and Button B for check-out.
Step 7 : Reboot your EDU PICO
pressing RST button to reboot, and you’ll see CSV file appear. All the data was recorded inside the CSV file.
