How to Create Temperature Gauge Using Pi Pico
- 14 Jul 2023
- 1083
Join us in this tutorial as we create a temperature gauge using Raspberry Pi Pico and a servo motor! We'll cut a cardboard paper into a half circle, label it with temperature ranges, and attach a servo horn for the temperature indicator. With coding, we'll make the servo move the dial, displaying different temperatures interactively.
Connect servo motor to port GP12.
Unzip the file, and locate this library:
- adafruit_motor
Copy and paste it into "lib" folder on your CIRCUITPY drive.
Project complete
Take a piece of cardboard and cut it into a shape that looks like a half circle. You can use a compass to draw the curved line. Remember to write down the numbers on the cardboard to show the temperature range you want.
Next, make a small hole in the cardboard. This hole will be used to attach the servo horn, which will act as the temperature indicator. By moving the servo, we can show different temperatures on the gauge.
