![Getting Started | Using Raspberry Pi Pico W with Blynk Getting Started | Using Raspberry Pi Pico W with Blynk](https://static.cytron.io/image/tutorial/getting-started-using-raspberry-pi-pico-w-with-blynk/Thumbnail%20(1).png)
- 06 Jul 2023
- 1877
In this tutorial, we'll show you the simple steps to connect your Raspberry Pi Pico W to the Blynk platform, enabling you to create exciting IoT projects effortlessly. Learn how to set up the Pico W, establish a connection with Blynk, and control your devices remotely through a mobile app.
Setup Blynk
- go to Blynk website, create a new account, and log in
- create a new template
- from datastream add a virtual pin
- then add a new device
- from the web dashboard add a switch
- now copy the token and let’s start making the code for Pico W
Required Libraries to Build the Code
Unzip the file, and locate these 2 libraries:
- adafruit_requests.mpy
- simpleio.mpy
Copy and paste them into "lib" folder on your CIRCUITPY drive.
Project complete
Now you control your Pico W through Blynk platform. You can also use the application on your phone to do the same thing. All you have to do is to sign-in to your account, click on Pico W device, then from the widget box add a switch to control the GPIO pin.
Maker Pi Pico Base with Raspberry Pi Pico WSH (...
RM74.90 RM76.90
