![DIY micro:bit Maze Game DIY micro:bit Maze Game](https://static.cytron.io/image/tutorial/diy-microbit-maze-game/Youtube%20Thumbnail.png)
- 20 Feb 2023
- 3144
In this DIY micro:bit Maze Game tutorial, we'll show you how to create a fun and interactive maze game using the micro:bit. With step-by-step instructions and easy-to-follow coding, you'll be able to assemble your own game in no time!
- Follow the code block in the picture above
Build the game
- To build the game, you will need cardboard, aluminum foil, ice cream sticks, and a hot glue gun
- Glue the ice cream sticks on the cardboard
- Bring a piece of cardboard and attach it to the backside
- Using cable ties attach the micro:bit on the cardboard
- Connect the crocodile clips to micro:bit this way
- Set up the ending points
- To make the ball, take a sheet of paper then start scrunching the paper, then bring some water and let the paper get wet, and then keep rolling until you have a nice circular ball. Lastly, wrap it with aluminum foil
Project Complete
To score a point, you must reach a goal point, which will add one point to your score. Once you've reached a goal, you'll need to navigate your way to the next one to continue scoring. Try to collect as many points as you can within a 30-second time limit.
micro:bit Junior Kit (V2)
RM85.00
