DIY Bubble Blower Using REKA:BIT With Micro:bit
- 27 Aug 2021
- 614
Let’s learn how to make a bubble blower game that works with the noise you make !! Cool isn't it? Join me in this tutorial to find out how ?✨
Step 1: Components and Tools
- 1x Servo Motor
- 1x Shaft Motor
- 1x Powerbank
Tools Required:
- 1x 4 Blades 56mm Motor Propeller
- Ice Cream Stick
- Bubble Soap
- Hot Glue Gun
All listed components can be found on our website Cytron Technologies
Step 2: Make The Base
Using a hot glue gun, attach one ice cream at the top of the two other ice cream sticks making a H shape | |
Attach another ice cream stick vertically on the left side | |
Attach another ice cream stick vertically on the right side | |
Place another ice cream stick horizontally on the top as shown in figure 4 | |
Stick a bubble wand on the servo motor, then attach the servo motor on the top side, as shown in figure 5 | |
Attach the shaft motor vertically as shown in figure 6 |
Step 3: Connection
- Connect the servo motor to the S1 port
- Connect the shaft motor to the first terminal
Step 4: Code
Well Done!
Great! .. Now, turn on the REKA:BIT and start making some noise to let the fan move!
Don't forget to show your amazing project to your friends, I'm sure they will be curious to know how you made it.
