Control Servo using Potentiometer With EDU PICO
- Solehin Rizal
- 05 Apr 2024
- 722
What is a Servo Motor?
A servo motor is a special type of electric motor that can rotate a specific angle (usually between 0 and 180 degrees) with precision. It comes with a built-in control circuit that allows it to receive instructions and move to a desired position. Servos are widely used in robotics applications and projects that require controlled movement, like animatronics or robotic arms.
This tutorial will guide you through controlling a servo motor using a potentiometer with the Raspberry Pi Pico W and the EDU PICO learning kit.
Coding
