![Control LED on EDU:BIT Using IoT Blynk App and Raspberry Pi Control LED on EDU:BIT Using IoT Blynk App and Raspberry Pi](https://static.cytron.io/image/tutorial/control-led-on-edubit-using-iot-blynk-app-and-raspberry-pi/RPi-Microbit-Blynk.jpg)
- 12 Aug 2020
- 835
Continue from previous tutorial, since the Raspberry Pi has WiFi, I will try to control the LEDs in EDU:BIT using the Blynk app. The idea is, I will program the Raspberry Pi to read data on the Blynk server, and then send the data to EDU:BIT via serial USB communication. Then the EDU:BIT will control the LED based on the data received.
This video shows how to control LED on EDU:BIT using IoT Blynk app and Raspberry Pi.
- Raspberry Pi 4 Model B (2GB)
- Raspberry Pi Approved MakerDisk microSD Card with RPi OS
- Maker pHAT
- EDU:BIT Training & Project Kit for micro:bit
This is python sample program for micro:bit (top) and Raspberry Pi (bottom). You can use mu editor to program micro:bit and Thonny Python IDE to run program in Raspberry Pi. Please install python Blynk library with following command.
sudo pip3 install blynk-library-python
