![Color (RGB) detector using CircuitPython on Raspberry Pi Pico Color (RGB) detector using CircuitPython on Raspberry Pi Pico](https://static.cytron.io/image/tutorial/color-rgb-detector-using-circuitpython-on-raspberry-pi-pico/Cover-BI.jpg)
- 20 Apr 2022
- 1869
This tutorial I would like to share how to interface the color sensor (TCS3200) using CircuitPython on Raspberry Pi Pico.
This is the list of items using in the video.
- Raspberry Pi Pico
- Colour Sensor Module
- I2C 1602 Serial LCD
- Strip Board
- Soldering Iron Kit
- USB Micro B Cable
- Straight Female Header 1x40 Ways
This is CircuitPython sample program. You need to include this library in your CIRCUITPY/lib folder. You can download it from CircuitPython Library Bundle.
- simpleio.py
For lcd.py and i2c_pcf8574_interface.py, please save it in your CIRCUITPY/lib/lcd folder. Yes, you need to create the lcd folder in the lib folder.
RM33.00
Raspberry Pi Pico Microcontroller Board
RM17.90++ RM19.90++
