Build an IoT Plant Monitoring System with MicroBit and Grove WiFi Module
- 01 Nov 2021
- 1249
IoT-based Smart Farming improves the entire Agriculture system by monitoring the field in real-time. Come join me in this tutorial to learn how to keep track of your plant soil moisture with the use of the MicroBit and Grove WiFi Module, from anywhere in the world!
Components Requird
- Connect the analog pin (A0) of soil moisture sensor to P1
- Follow the steps here to create a channel in ThingSpeak, and get the API key to store your data in the cloud.
If you want to learn more on how to send data to ThingSpeak using MicroBit with grove WiFi module, please check the video tutorial here - After completing the code, download it on microbit
Project Completed
Upon completing the project successfully, the reading value of the sensor should appear in your channel at ThingSpeak.
Note: The dryer the soil, the higher the reading value.
