Build a Shooting Game Using micro:bit
- 31 Dec 2022
- 2654
Hello makers, how good are you at aiming and shooting?
Want to test your skills and challenge your friends? In today's project, will be making an easy and fun shooting game using micro:bit. Let's get started.
- micro:bit
- Crocodile Clip
- Follow the code block in the picture above
Build the game
- To build the game, you will need cardboard, metal wire, aluminum foil, and a hot glue gun
- Glue the base
- Cover the target, and the blocker with aluminum foil
- Attach the blocker
- Hang the target using metal wire
- Bring the micro:bit and attach pin 0 to the target, and GND pin to the target blocker
Project Complete
Use a rubber band and a small piece of cardboard to hit the target. Try to score as many as you can. To make the game more challenging, try to shoot from a far distance.
