Automatic Plant Watering System Using REKA:BIT
- 22 Jul 2021
- 3001
Let's learn and build a simple automatic watering plant system using REKA:BIT. ? Press button A to get the sensor reading.
- REKA:BIT - Simplifying Robotics with micro:bit
- Grove - Capacitive Soil Moisture Sensor (Corrosion Resistant)
- Micro Submersible Water Pump DC 3V-5V
This sample program is using MakeCode. Before that you need to add the extension of "rekabit".
