Smart Plant Monitor Using Microbit and Soil Moisture Sensor
Water is necessary for the life and survival of all plants, it is essential for the transportation of nutrients and sugars from the soil to the plants. In order to keep your plants alive and well you must water them always.
Do you usually forget to water your plants? You don't have to worry anymore!
With micro:bit, Wi-Fi module, and soil moisture sensor you can create an awesome project to remind you to water your plants when they get dry.
circuit diagram
  • Connect the grove Wi-Fi module to P15 and P16
  • Connect Maker Soil Moisture sensor to P2 and P12
microbit screenshot 2 30
Connect your REKA:BIT to your device and open MakeCode editor to start programming.
  • Add “ESP8266 Cytron” extension and follow the code block in the picture above
  • Follow the steps here to create Telegram bot. Get the API key of the Telegram bot and chat ID.
    If you want to learn more on how to send messages to Telegram, please check the video tutorial here
  • After completing the code, download it on microbit
Project Complete
screenshot 1 1 33
Upon completing the project successfully, you shall receive a message notification on your Telegram once your plant is dry.
Related Posts
RBT Automatic Plant Watering Project - Automatic Pet Feeder
Do you know that by using the same component from the Auto Plant Watering Project Kit can be turned into an automatic pet feeder?....
RBT Auto Plant Watering Kit Project - Not Enough Water!
Nooooo, my plant is dying because I didn't refill the cup of water eventhough I turned on the auto plant watering system for days! What should I do?....
RBT Automatic Plant Watering IoT Project Using Blynk IoT
Turning RBT Automatic Plant Watering Project Kit into an IoT project that allows users to control and monitor using Blynk IoT...
