[Holiday Notice] Please be informed that our office will be closed on September 16 & 17 in observance of a public holiday. Kindly note that all orders placed after 12:00 PM (GMT +8) on September 13 will be processed on September 18. Thank you for your understanding, and we apologize for any inconvenience caused.
IoT-Based Door Lock Using micro:bit and Blynk
With this IoT-based door lock, users can have access to control the door lock remotely through their smartphones. All you need is a micro:bit, Grove WiFi 8266, and servo motor.
  • Connect the grove Wi-Fi module to P15 and P16
  • Connect the servo motor to port 1
Blynk Setup
  1. go to Blynk website, create a new account and log in
  2. create a new template
  3. from datastream add a virtual pin
  4.  then add a new device
  5. select the template that you have created
  6. now copy the token and paste it into the micro:bit code
  7. on your phone, open Blynk app and click on micro:bit device
  8. from the widget box, add a button and select virtual pin 0
Connect your micro:bit to your computer and open MakeCode editor to start programming.
  • Add “ESP8266 Cytron” extension and REKA:BIT extension as well, then follow the code block in the picture above
  • Type in the name and password of your WiFi
  • Paste the Token that you have copied from Blynk, and type in "V0" in Pin section
  • After completing the code, download it on microbit
Project Complete
Now you will have access to control the door lock remotely through your smartphone.
