How to Set a Password for a Door Lock Using Microbit
- 03 Aug 2022
- 1403
With only two buttons in microbit, can we make passwords to build security projects? YES, we can!
Let's learn how to set a password for a door lock using microbit. ?
- Connect the servo motor to the first servo port
Connect your REKA:BIT to your computer and open MakeCode editor to start programming.
- Add âREKABITâ extension and follow the code block in the picture above
- After completing the code, download it on your micro:bit
Project Complete
Upon completing the project successfully, the door lock will open once the user enters the correct passwordÂ
