How to Make a Light-Following Sunflower Using micro:bit
Sunflowers face the rising sun because the morning warmth attracts more bees and also helps the plants reproduce more efficiently. Let's make a sunflower that reacts to the light level in the surrounding using micro:bit.
sunflower circuit 50
  • Connect the servo motor to the first servo port
code pic
Connect your REKA:BIT to your device and open MakeCode editor to start programming.
  • Add “REKABIT” extension and follow the code block in the picture above
  • After completing the code, download it on your micro:bit
Project Complete
demo
Upon completing the project successfully, the servo motor will rotate based on the light level in the surrounding.
SG90 Micro Servo -17% Best Seller
SG90 Micro Servo
RM6.50 RM7.80
SG90 Micro Servo
Not Available
