ESP32 as WiFi co-processor for Raspberry Pi Pico
- 18 May 2021
- 1203
We want to create IoT related projects using Raspberry Pi Pico and program it using CircuitPython. We know that the Maker Pi Pico comes with a connector for the ESP8266. But unfortunately CircuitPython has stopped supporting this module. Alternatively, we can use ESP32 as a WiFi co-processor for the Raspberry Pi Pico.
This video shows how to add ESP32 as a WiFi co-processor for the Raspberry Pi Pico and program using CircuitPython.
- Maker Pi Pico OR
- Raspberry Pi Pico - Pre-soldered Headers with
- Maker Pi Pico Base
- Node32 Lite
- Breadboard 8.5x5.5cm (400 Holes)
- 40 Ways Male to Female Jumper Wire
- 40 Ways Male to Male Jumper Wire
You can get the sample code from Adafruit Learn page:
- Sample code 1 - code.py
- Sample code 2 - secrets.py and code.py
Don't forget to include these 5 libraries from CircuitPython Libraries bundle.
- adafruit_bus_device
- adafruit_esp32_spi
- adafruit_io
- adafruit_minimqtt
- adafruit_requests
- GitHub esptool.py
- NINA firmware
- CircuitPython - Raspberry Pi Pico
- CircuitPython Libraries
- Quickstart IoT - Raspberry Pi Pico RP2040 with WiFi
