Clearance sales 🌟Until 31 Dec 🌟 We commit to add more than 5 products to the list every 2 days. BUY NOW
DIY Fire Detection and Suppression with Raspberry Pi Pico
Learn how to build a fire detection and suppression system using a Raspberry Pi Pico, a flame sensor, and a water pump in this quick and easy video tutorial. Keep your surroundings safe from fire hazards with this DIY project!
  • Connect the flame sensor GP3
  • Connect water pump to motor terminal 1
Project complete
The code runs an infinite loop, checking the flame sensor for fire detection. If a fire is detected, it activates the water pump for 5 seconds and then turns it off.
