DIY Buzz Wire Game Using micro:bit
- 27 Oct 2022
- 1487
Buzz wire is a challenging and competitive game. The goal of the game is to move the hook carefully along the steel wire without touching it. When the hook makes contact with the wire, you will hear a âBUZZâ sound. The goal is to be quick and efficient, with as few touches as possible.
Â
Bring your micro:bit and letâs learn how to DIY this fun game!
- REKA:BIT with micro:bit
- Crocodile Clip
- Steel wire
- Connect 3v pin to the hook
- Connect p0 to the maze
- Connect p1 to the finish point
Connect your REKA:BIT to your computer and open MakeCode editor to start programming.
- Add (REKA:BIT) extension and follow the code block in the picture above
Project Complete
When the 3v wire is touching pin0 you will hear an alarm sound, and when the 3v wire is touching pin1 (finish point) you will hear a melody.
