This tutorial is application of MD10POT motor driver that can be use directly from the board without programming. The turntable is produce using 3D Printing method...
This is a RC Sumo Robot based on MDDRC10 Motor Driver. The sizes are 15cm(L) x 15cm(W) with below 1kg (weight). The spec is for 1kg Sumo Robot Competition..
This article will take you through a step-by-step journey, covering everything from prepping the prints to choosing the right paints and techniques for a flawless finish...
In 3D printing, precision and flawless finishes are highly sought after. However, a persistent challenge that often mars the final result is the presence of a visible seam known as the Z seam...
Understanding the role of shells is vital for achieving optimal print results and ensuring the desired characteristics of the final product. The purpose of this article is to provide a comprehensive..
Modifying existing 3D models offers numerous benefits, including the ability to personalize and customize designs, save time and effort by building upon existing structures, learn and improve design..
Lithophanes are special artworks that use light and shadows to create beautiful images. Traditionally, making lithophanes required a lot of skill, but now, thanks to 3D printing..
Proper support removal is essential for achieving a clean, smooth, and professional finish on your 3D prints. It requires careful attention and the use of appropriate techniques to avoid damaging..
PLA smoothing techniques provide effective methods to minimize these lines, resulting in smoother surfaces and professional finishes. In this guide, we will explore various PLA smoothing techniques..
Cura's support blocker feature is a great tool that lets you prevent support structures from being printed in specific areas where they're not needed, saving you material, time, and effort in post-pro..
